SM102 auto grease not able to reset
  • The grease distribution blocks where the sensors are mounted has a small pin inside that goes in and out due to grease pressure, the pin gets stuck very often and requires a thorough cleaning of the distribution block
    Usually, there is a lubrication circuit end-of-stroke pressure sensor.
    - it is necessary to control the quality of grease used
    - If you forgot to fill the bucket with grease it may be an air problem and you must bleed the circuit
    -test the central lubrication limit switch sensors if they are defective
    -activating the sensors manually may solve the problem
    -controller of the electric and hydraulic control circuit of the central lubrication
    Please note: the machine must not be turned without any problem, the problem is because after 72 hours the machine, as a safety measure, reduces the maximum speed to 8000 rpm after 3000 rpm
