SM102 Auto Plate Clamp with Air Bag
KhorWK
2021
46
Malaysia
Does anyone know where to refer how to dismantle the Auto Plate Clamp with Air Bag? Any manual to refer? Thanks guys.
We could help you to replace the inflatable chamber but for the documents difficult to have them, I would like to know which of the inflatable chambers that the concern, Higher or lower. Thank you
  • Hi Beguin, thanks for your reply and info. However, I found not the inflatable faulty but it the 4mm blue hose break and need to be replaced. So, need to remove the gear out.
    If one hose broke (most likely from exposure to oil/chemicals), you’d be wise to replace all lines for that clamp/radial valve. You’ll have to remove clamp to accomplish this.
    hello, can I see the place the pipe is broken; if the place is not accessible it will be necessary to dismantle some things for a good repair. Thank you.
