Hi,I am an experierenced Press Operator (38yrs),the problem you are experiencing is common to the 2 Heidelberg Perfector Presses in our shop,we have a 2 Color and a 4 Color both with Perfectors,with some age and impressions under there belt.You can spend major money and get a Heidelberg Mechanic in to fix this problem,or,you can try my $1.00 bandaid solution that will help you're problem,I have used this method on both the 2 Color SM74,and a 4 Color GTO both with perfector units,neither press would fit the image side to side,and,it didn't matter if it was grain long or grain short,I'm sure you have the same problem regardless of the Grain direction,and yes,the stretch will be more pronounced on a grain short sheet,common sense,.. My Solution,.. Get a sheet of sandpaper,Mediun grit,attatch some double sided tape to the back side of the sandpaper,a good carpet 2 sided tape is what I use,cut strips approximately 1/4" to 5/16" wide the length of the sandpaper,then cut these strips into 3/8" to 1/2 " long pieces,the width of the lower pincer gripper,clean any grease or ink off the lower pincer gripper,remove the tape backing,and attatch a piece of sandpaper to only the lower gripper's of the pincer bar, 1 piece on each of the lower pincer grippers,by doing this,you build up the lower pincer gripper to be level with the Transfer Cylinder grippers at the time of Sheet transfer,so now, there is no longer any sheet distorsion at this transfer point,the sheet transfers flat,and the image width will now be the same on both printing units..If you don't feel comfortabe using sandpaper,try something else,Seems hard to believe,but,it works GREAT,The 4 Color Heidelberg was also fitted this way,previous to this,the 1st two units would not fit the last two units,my perfector is in the middle of the press on the 4 Color.A Heidelberg Mechanic may not like my Bandaid Solution, BUT, it does work,try it and get back to me,I only change the sandpaper pieces when the double sided tape becomes mushy and you can see the sandpaper pieces starting to move slightly,at that time,remove all the sandpaper pieces,clean the residue off,and install new sandpaper pieces,I even Perfect with the sandpaper there,and have had no problems....Experienced Pressman from Ontario,Canada
