qm46/pm46 locks up?
Inky
53
Ipswich
My Printmaster46 (QM46) has just started locking up, (stops dead) I don't know if this is relevant but if I wait a while the compressor then kicks in for a while and then everything returns to normal.
I am confused as the press can run and then literally lock up within a split second of the last sheet being delivered, (no gentle slow down) or it can lock up as soon as the plate clamp shuts upon loading a plate.
Any ideas at all would be great as I'm struggling till I can call an Engineer.
Many thanks
Harvey
Do you happen to see if a code appears on S56......leave it on and keep an eye on the display.
  • Hi,
    just loading a plate on pu2 and as soon as the clamps shut it stopped dead and the compressor came on for a minute.
    Checked code ERR2 02-05
    Many thanks Mr Heidelberg where in the UK are you?
    Harvey
    removed plate manually err3 01-03
    shut front door err3 00-00
    Harvey
    Machine idling with dampeners on
    err 1 11-05
    pump kicks in for a while, able to start again
    err1 01-03
    err2 01-02
    pump kicks in then I can continue
  • I called an Engineer out and they replaced a ram that was leaking, no improvement. Now I've had to order a new lower limit switch, fingers crossed.
    I was shocked Heidelberg wanted £750.00 up front on my credit card for a call out as I dont have an account, is this normal? or even worse £75 to talk to someone technical.
