Jerky feeder
RichardK
2007
685
Derby, UK
Hi guys, s'been a while but here's an issue that maybe someone can shed a little light on.
At slow speeds our Komori L626 feeder 'jerks' a little, ie the feeder tapes pause ever so slightly before continuing.
Our pressman is of the opinion that this is the major cause of feeder trips.
I've checked the drive chain and it seems well lubed and not too slack or tight.
Any ideas?
  • Exposing my ignorance (again) where does this live and have you any pointers for checking correct operation?
    Richard,
    On the older presses, the clutch was located under the cover on the drive side of the feeder. Often, a little WD-40 or other lubricant will free it up.
    The problem can also be caused by the feeder drag brake which should be located just to the operator side of the gear side cover. The old ones could be tightened but I'm not sure about the new electrically operated brake. There will be a sheet metal cover over the brake. Also, the brake pad may have a glaze which can be removed with a medium grit sandpaper.
    With the feeder tripped, the drive shaft should be hard to turn by hand. If it turns easily, the brake is slipping.
    In my experience, the most likely cause of jerking feeder tapes has been a slipping drag brake.
    Cheers Klec & peheidelberg. It was the drag brake, there's a castellated threaded collar to apply more pressure - an 1/8th turn has sorted it.
    Smooooth as silk now - so no more excuses for feeder trips :D
    "Castellated" - so that's what you call that arrangement with the wings to hold the nut in place.
    Well it's what I call it (don't mean to say it's correct terminology tho'). BTW Komori calls the 'drag brake' Torque Keeper, sounds a bit medieval to me :D
    Sound exactly what the Mitsubishi's have, although you can hear the squealing ;)when its in trouble.
    Komori and Mitsubishi have 'borrowed' each other's technology for years so it's no surprise really. Having said that both are great presses...but my loyalty is with the big K.
    Richard does your Komori have bladder & roll blanket washer cartridges? If so do you have difficulty keeping the water spray bars free from clogging?
    Dave
    The washers we have are flat pressure plates not rubber bladders but we do have water jets. The water jets haven't ever clogged to my knowledge.
    When you unclog yours, does the material that blocked them feel crystalline? If so you may have a hard water issue, you could try a water softener.
    Right yours are similar to our B1. I didn't have time to ask the engineer when he took one for cleaning, although we've been using main water to refill and were advised yesterday to use deionised water.
    Just thought i'd ask thanks
    i dont wanna sound like im a takin the piss or owt, but you got an engineer in to remve and clean the wash spray bar?
  • Right yours are similar to our B1. I didn't have time to ask the engineer when he took one for cleaning, although we've been using main water to refill and were advised yesterday to use deionised water.
    You could fit an inline water filter to deal with the scaling. Filter Link
    Dont even go there, yes i got the in house electrician/engineer. Not cos i'm as thick as pig ****, but i was far to busy.
    letterpress/litho....i strip it..... fix it..... print it.
