Komori lithrone g40 feeder sensor trouble
adelpro
2019
alger
hello everyone here is for a few days I have a problem with the sensors through sheet and detector advance sheet nothing works mae does not stop if a sheet goes through or advances ome help please
sorry for my bad anglish
first make a visual check...photocells must be lit ,clean of dust
then manually insert a sheeet of paper covering photocells and with a non coductive (plastic) screwdrive set sensitivity (from white potentiometer )individually, following the red-green leds indication
  • first make a visual check...photocells must be lit ,clean of dust
    I have already cleaned well and made a calibration to the cell (IM) pressurized, but nothing is changed.
    Thank you for answering
    Does feeder continue to run, or does feeder stop and press takes in "tripped sheet"?
    Does feeder continue to run, or does feeder stop and when I stop the feeder, the machine continues to press about 20 leaves of delay so the cell of (missing leaf) starts ringing takes in "tripped sheet"?
    when I stop the feeder, the machine continues to press about 20 leaves of delay so the cell of (missing leaf) starts ringing . if you want I send you a video on WhatsApp here is my number: +213 771 696 734
