SAICPRINT
- Joined
- 2014
- Posts
- 49
- Geo
- Chicago
Trouble shooting missing sheet detector,
Sheets feed fine when impression off however
when impression selected machine trips off.
My first question is does the missing sheet / mis aligned detector
only function when machine is ON Impression? Or if the sheet is mis aligned
hitting only one gripper the machine should trip off?
I detached hose going to sniffer and was able to feed sheets on impression,
so I assume I have an air leak most likely in the feed gripper assembly since I
replaced all the hoses and cleaned/inspected the sniffer piston.
If there is not an air leak in the assembly could there be too much air pressure
going to the piston? or anything else to look at?
