Ryobi offset 920 series error E002 encoder input
Example is Vcc according with the data sheet of CPU, like +5Vcc. if is 5.5Vcc, is faulty the regulated power supply, some electronic board as Potentiomter for adjust the R. P. Supply, others NOT, you must have 2 alternatives ; 1) repair or 2) replace it...
2) the clock in the same way in the data sheet, you must identify the Pin for the CPU (clock) in MHZ, and replace, NOT repair, unless if you must identify ; Colder + dry joint solder in the component, behind of the component.
If everything is o.k, RESET the CPU, as according, with my schematic, or small Black Button.
Hi sir we have this problem too. We change CPU and we need Parameters how can i take parameter codes can you help fastly.
Sir we have codes A9996229-DC0C-40E5-8B75-6BC07C4BF75E.jpeg C5E87B64-A978-496C-9CEA-16C905F30E75.jpeg C5E87B64-A978-496C-9CEA-16C905F30E75.jpeg A9996229-DC0C-40E5-8B75-6BC07C4BF75E.jpeg
  • Sir , sorry do not have codes.
    You must go to the agency or factory.
    Unfortunately, there is no service in Turkey that this machine will look at directly, is there anyone we can contact ? :(
    look for the dealer, most near in your area, out of Turkey.
  • I cant find can you look for us please our machine doesn’t work now we have to much problems :(
    in the Middle East , must be some Agent, if NOT call to the factory, to indicate who is most near from you, o,k?
