Lack of air
Thank you very much for your help. The cards are working great, and we have full air performance again.
Greetings again,
my SM102-4, cpc2000 is lack of air.
-bow break
-Bogenauslage (outrigger?)
i bet somethging with the air star? it is counting.
air hose (Luftschläuche) were ok.
where to start checking?
LG Chris
Close the air inlet valve on the machine. If the compressor starts within 30 seconds and stops while indicating maximum pressure, then you don't have a problem with the compressor. In this case, you need to check and eliminate any leaks on the machine. If the compressor is unable to reach the operating pressure, then you must repair your compressor.
  • Close the air inlet valve on the machine. If the compressor starts within 30 seconds and stops while indicating maximum pressure, then you don't have a problem with the compressor. In this case, you need to check and eliminate any leaks on the machine. If the compressor is unable to reach the operating pressure, then you must repair your compressor.
    See my last post. We have fix the probleme.
    But thank you very much for your help! :)
