wohlenberg spm76
this is how it looks now
  • Hi sir;
    Please do this:
    Blessing
    hello sir. i have the same issue as this error. p-err
    i have replace the battery because it was dead no power and i still have "p err" displayed on screen.
    i tried this code showned on image you send it but is still the same.
    any idea what the foult is or does have any resseting code
    id be greatfull.
    thank you
    Do you know how to insert the machine parameters. If not give your e mail address and I will email how to do this
    I lost parameters from our machine, Is it possible to get instructions how to feed parameters to the machine?
    First and foremost, Check for proper grease on the leadscrew and backgauge guide. You want to use a light weight lithium based greased. White Lithium is what I recommend.
    Make sure the fingers of the backgauge arent dragging. Sometimes decri builds up under them.
    All that checked and corrected then you will need to set a parameter.
    Locate a small hole above the memory buttons. There is a switch that can be pressed through that hole. That is your SERVICE BUTTON.
    You will need to start by pressing P, do this more than once to make sure you are in the main start up screen. Then push SERVICE BUTTON and C at the same time, then press C by itsself, then type in code 2412 then press MEMORY then SERVICE BUTTON and 0 at the same time. This shoud bring up a special screen. Change the parameter highlighted by pressing C then keying in your new value then MEMORY.
    The list of parameters should be in your manual. If they are incorrect or showing weird letters, you will need to change them all. Press SERVICE BUTTON and the parameter number you need to change to move the cursor.
    didn’t work for our machine, might different type
    Wahlenberg than ours. Service button is next to screen ( at the other side than memory buttons).
    I dont know what system your machine has without seeing a picture. I might be able to help if you show me.
    Here is pic ofour machine
    Hi all! How are you doing today? I hope you all have a great day!
    I need your help fellas. I need the parameters for Wohlenberg spm76. If anyone has them, can you pls send me an email with the same at:
    dkachurov@gmail.com
    Thanks in advance!
  • Hello, I need instructions or a copy of the manual with the parameters to configure a Wohlenberg 76 SPM whose RAM memory was erased. Could you please help me? I have the electrical and user manuals, but the machine doesn't have the table with the parameters and instructions on how to enter them.
