hi
hi sir
hi sir....immediately i test the micro switch it is goodP-err usually means when joystick moved to automatic and programm run button pressed joystick microswitch not seen, probably faulty
nothing at all in the memory.... I try to write new program and save it... but i failed.... the machine just work manuallyHi first does the machine cut in manual, can you use existing programs. If so then maybe memory full
Yes, please with thanksDo you know how to insert the machine parameters. If not give your e mail address and I will email how to do this
Hi sirTest the battery lithium, by 3.6Vdc, if is low replace it, with the same type
you have only 10 minutes , otherwise you can loose all Information in RAM memories.
2) Please, test all power supply from Vdc, +5Vdc+24Vdc, in tolerance with 0.7% up or down, otherwise, replace o repair, the cutter will NOT work, in any way, do it carefully, according with his schematic diagrams electrical, and Good tester DMM.
I received your message gladly, I looked for a lot about this file ..Do you know how to insert the machine parameters. If not give your e mail address and I will email how to do this
my dear friendsDo you know how to insert the machine parameters. If not give your e mail address and I will email how to do this
