John Van Hoorn
- Joined
- 2013
- Posts
- 31
- Geo
- Northern Illinois
Sounds like your transfer cylinder shifted on the transfer gear. If the bite is truly different and consistent that may be the problem. Your transfer point could be shifting due to bad cam follower or incorrect gripper setting. It would have to be drastic to be able to be seen by eye. Carefully have somebody turn the press by hand while you hold tension on the back of the sheet. Pay special attention to the side of the gripper shaft that does not have the cam follower on it. If it breaks hold while transferring from on cylinder to the next you will have found your problem
