Difference between Heidelberg SM,CD and XL
Discussion in '4-Color Offset Presses +' started by faizeej, Jul 22, 2016.
Tags:
  1. faizeej
    faizeej Member
    Jan 2010
    35
    Karachi, Pakistan.
    Dear All
    Can anybody explain in detail the difference between Heidelberg SM, CD and XL
  2. Meny
    Meny Senior Member
    Apr 2008
    773
    Israel
    SM - SMALL impression & transfer cylinders - one sheet at a time , so heavy board needs to follow the small cylinder and you get marks scratches and un-even impression on board. for paper - OK
    CD - big cylinders - 2 sheets at a time , so sheet will curve less - older model . it is a 5 oclock press , so you get marks on solids & rasters.
    XL - a newer mopdel , big cylinders and 7 oclock technology.
    this is in short :)
  3. faizeej
    faizeej Member
    Jan 2010
    35
    Karachi, Pakistan.
    what do you mean by 5o clock and 7 o clock technology?
    and SM means speedmaster, CD means Cardboard diameter, what is XL means?
  4. Meny
    Meny Senior Member
    Apr 2008
    773
    Israel
    5 oclock design - the sheet printed changes gripper set before the tail is fully printed - you may get marking from the change in pressure .
    7 oclock design - the sheet changes gripper set only after it is fully printed on the former unit - more stable and no sock marks.
    CD is Cardboard druk .
    XL is extra large - bigeer sheet :)
  5. aqazi81
    aqazi81 Senior Member
    Oct 2009
    821
    KARACHI PAKISTAN
    I hope this helps.
  6. alibryan
    alibryan Senior Member
    May 2014
    148
    Pacific NW
    SM stands for SpeedMaster.
    CD signifies a Carton Press - it's designed to allow for printing on thicker board stocks.
    XL stands for Extra Long (press) - meaning the press delivery is extended (press usually has a coater and is only available with high pile)
    5 o'clock and 7 o'clock is a term for the impression cylinder placement, as shown in the drawing in Aqazi's post. Both arrangements are found on different model year presses, both older and newer. For instance: I've seen the 7 o'clock design on a late 80s era SM74 and the 5 o'clock design on an '01 SM74. I've also seen the 5 o'clock arrangement on an '01 SM52. Both arrangements will mark the sheet, especially presses with single transfer cylinders. To me, the biggest difference between the two designs is the 5 o'clock is really difficult to reach if trying to clean the cylinder manually, whereas the 7 o'clock is easily accessible.
  7. exheidmech
    exheidmech Senior Member
    May 2009
    674
    USA
    SM = Speedmaster. These machines are available in 52, 74 and 102 sizes. Cylinder configuration is 2 transfers and a double cylinder between a single sized impression cylinders. This cylinder configuration makes printing on board difficult especially for short grain paper. Marking is almost a sure thing when printing on short grain. Typically these machines are rated at a lower speed than the CD or XL machines. SM102 machines will also not be available with back cylinder washers. This is the lowest end machine Heidelberg makes, still a great machine for those printing on paper, not so much for board.
    CD = Still a Speedmaster with a few differences. These machines are available in 74 and 102. Most notably is the cylinder configuration. On CD74 there is 1 double sized transfer between each double sized impression cylinder. This is a high end, high speed machine great for paper or board. CD102 will have 1 triple sized transfer between each double sized impression. This also is a great press for board or paper. Downside is the double/triple sheet transfer combo means that there is 6 different sheet transfer combinations making troubleshooting for mechanics more labor intensive.
    XL = The XL really means nothing other than the fact that this is the highest end product that Heidelberg makes. The XL is available in 75 105 106 145 and 162. These machine will offer you all the bells and whistles you could wish for in a printing press. Every one of these machines is excellent for printing on paper or board. Very high speed and very high reliability.
  8. exheidmech
    May 2009
    674
    USA
    The XL really means nothing. Definitly does not mean Extra long. 2 or 4 color XL75 or 105 are not terribly uncommon. 10 or 12 color SM102 are also very common. As far as the SM74 which was introduced in 1995 the cylinder configuration really has not changed even to this day. Today it is knows as the SX (which also means nothing) and the cylinder configuration remains the same as in 1995. You are correct however that the SM52 and 74 can be marking machines if not properly set up especially when running anything over 14pt.
  9. alibryan
    May 2014
    148
    Pacific NW
    Good to know about the XL machines, I didn't know that. Are there any XLs made without an extended delivery?
    I used to work with a seasoned SM operator who called them SlapMasters, because of the marking problems he experienced with them and claimed were inherent of its' design. Though I never did ask him what model year(s) he was talking about.
  10. aqazi81
    Oct 2009
    821
    KARACHI PAKISTAN
    Yes! Xl also made without extended delivery.
    SM102 and SM74 are prone to marking if not setup correctly. You need to have installed super blue or anti-marking jackets properly, also air settings in transfer cylinders.
  11. Thayanithi Kokulan
    Thayanithi Kokulan Member
    31
    Sri Lanka
    Now heidelberg is promoting SX series can anyone let me know what are the pros and cons of SX with respect to other models.
  12. mz000
    mz000 Member
    Jan 2011
    13
    Egypt
    any feed on this matter ?!
  13. Mehdi Sellahi
    Mehdi Sellahi New Member
    Feb 2020
    Algeria
    Hi everybody,
    - please can you tell what means each letter added to the heidelberg SM CD 74 5 colors , ( LX , P , H+L , DI , H+LX , PL , PP , H ,PH , PP , +L, F 4P....).
    i know just that F is format of paper 74X60.
    - also how can i know frow the model if it contains coater and the UV Dryer
    mz000 likes this.
  14. Mehdi Sellahi
    Feb 2020
    Algeria
    LX indicates the machine hasa coating unit with an extended delivery
    P means that machine has perfectors
