Static PR
Neess
165
Aarhus, Denmark
Hello.
On our iGen150 press we have a lot of issues with static PR belts, they run about 4-5k impressions and then the PR Drive velocity error starts to pop up. Meaning we use alot of PR belts lately.
Any advice?
Make sure to clean both pr drive rolls at the bottom of the pr assy thoroughly with a rag and 409 everytime you remove the pr belt for any reason.
  • Make sure to clean both pr drive rolls at the bottom of the pr assy thoroughly with a rag and 409 everytime you remove the pr belt for any reason.
    add to that a CLEAN rag. I use alcohol.
    I once went through a whole day with this error, thinking it was a bad belt... turns out I was just cleaning it using a dirty greasy rag... causing slippage.
    We always do a good clean with the right cleaning solution(not the soapy one)
    The issue seems to have been the tourqeroller slipping and causing static buildup.
    I usually clean both rollers until they're nice and dark black. That takes care of it 95 % of the time.
  • I have been changing PR belts on 6 different iGens in the last 10 years, never had a PR belt going so static it nearly cant be tanke off without cutting it after only 3.000 impressions.
