paper wrapping in t head and main unit.
kblack
2012
83
vermillion,sd
I have been having problems with paper jumping up into the t-head and main unit on my 9910. Does anyone have an answer of why this is happening. A total mess to clean up and alot of time. thanks kblack
A number of things come to mind. Are to grippers on the impression cylinder opening and closing correctly? Does the gripper shaft need oiling. What type of stock and ink are you running. If the image is too heavy plus tack of the ink might be pulling the sheet out of the grippers as it sticks to the blanket. Use tack reducer to help release off the blanket especially if you are running enamel stock. Make sure the pile is just high enough to feed only one sheet at a time. If doubling it might send the second sheet flying. With t-head blocking your view it is hard to see the feeder. Swing the t-head out of the way to get a good view of your feeder and make sure it is set up correctly for the stock you are running.
  • Forum posts represent the experience, opinion, and view of individual users. The Color Printing Forum does not necessarily endorse nor share the view of each individual post. When making any potentially dangerous or financial decision, always employ and consult appropriate professionals. Your circumstances or experience may be different.
