Heidelberg GTO 52 - Paper wont feed.
Lama Manu
2019
6
Samoa
Hi All,
Having problems with my GTO 52 - Press also (not a good week btw) it runs and we still can inch etc but when you press Production/Impression while running, it wont pick up the paper. i have checked the solonoid inside the panel just above the vaccum pump and all seems ok. It seems like when the machine is running the Solonoid should close when you press the production button so that it sucks in more air? but it doesnt do that..appreciate any help on this please.
Cheers, Manu
Hi sir;
Please test the limit switchs; B72+B73+B74 , for faulty, dirty, loose wire, or bad adjustment
2) contactor d 11,if are Pull in, look, for loose wires, corroded, voltage to the coil, or defective contacts +coil.
3) solenoid S9, lood for defective, dirty, or worn, loose wires, or lack of voltage, Clean it or replace it.
