Keeping It Real
- Joined
- 2023
- Posts
- 39
- Geo
- England
To install this app on your iPhone:
Note: This feature may not be available in some browsers.
It is good to learn first, then write.It s noy possible to run without
Perhaps i don t understand please explainIt is good to learn first, then write.
Please explainTry working without a tacho.
We managed to clear the fault
Now have another
we can inch and crawl the press however the RED T light comes on when we try and run the press
the motor tacho does have a voltage reading 3.4 vdc when on crawl
When we press run no power is sent to the motor and the RED light shows
does anyone know what the red light is for
- Tacho ?
- Encoder ?
- other ?
Older machines have the option of running tacho or rotor (armature) voltage. The connection diagram can be found on the last page of the electric documentation of the machine. It is done with a small screwdriver. 3 bridges must change places.Perhaps i don t understand please explain
Thank you if you don’t mindOlder machines have the option of running tacho or rotor (armature) voltage. The connection diagram can be found on the last page of the electric documentation of the machine. It is done with a small screwdriver. 3 bridges must change places.
I'll take a picture of it for you tomorrow.
