To install this app on your iPhone:
Note: This feature may not be available in some browsers.
Please check very well Battery with same characteristics.
2l Reset switch ( small) in CPU board down in the control box, where is located the battery .
Blessings
This does not require a CPU reset; there is just a very simple operation by entering the service with a password of 4 numbers and then you go to the menu for deleting data from memory A and B
Noted, thank you. I will discuss with my technician.I believed, that you did Not understand very well, my tech recommendations, starting with the Regulated power supply of the machine+ CPU, and the Clock, etc.
Please do , what am tell you , if you want to fix it, and Resolder with flux, x possible Dry+ Cold solder joints.
How to erase the memory bank sir can you please sayThis message indicates that all of the data in memory zone A or B cannot be accessed due to a fault or aging battery.
This message may also appear when using the PMS card for the first time, given that memories A or B have not yet been initialized by an erasing process.
It is then obligatory to erase the memory zone in order to proceed to a new storage.
If the fault cannot be eliminated by erasing, the battery on the CP must be changed.
Sir can u please say how to erase the programThis message indicates that all of the data in memory zone A or B cannot be accessed due to a fault or aging battery.
