Good afternoon,
Thank you for your detailed feedback regarding the Polar 115E – Error 286.
After reviewing the behavior you described (error appearing during warm-up and repeatedly around the 531 mm position, despite the inductive sensor giving a signal), the most probable root cause is a loss of mechanical reference of the backgauge.
This usually comes from one of the following factors:
Even if the inductive sensor reacts, the switching flag may be slightly out of position, especially after thermal expansion during warm-up.
Any looseness or shifting creates a mismatch between the real backgauge position and the position calculated by the system.
A weak or unstable pulse generator can cause an inconsistent position reading, often visible at specific travel distances (such as 531 mm).
Recommended Solution
Perform a complete reference run of the backgauge to recalibrate the mechanical zero point.
Check and realign the switching flag of the reference point sensor; ensure correct distance and timing when passing the sensor.
Inspect the mechanical connection between the spindle and the front extension part; tighten or correct any play or misalignment.
Test the reference point switch (B341) and verify signal stability when the machine is warm.
Check the pulse generator, especially for signal loss after heating.
In most cases, the issue is resolved by correcting the switching flag or eliminating mechanical play, then performing a new reference run to update the reference value.
Let me know if you need support with step by step diagnostics or adjustment.
Whatsapp +212700552467
Kind regards
