Plate thickness and packing for 226 Sprint
Di Nut
56
USA Mtn. Time.
What is the proper thickness of plate to run on the 226II Sprint? Also what would the packing be for that plate? We are currently running a 12 mil plate but have been told that we should be running and 8 ml. We are having some issues with premature wearing on image on plate and are trying to isolate the problem. Thanks
If you look at the opside of the unit 2 cover you will see a cylinder arrangement diagram this will give you your plate undercut.You should be packed .1mm or .004" over bearer.Does this press have Semi Apc Plate changers.
  • What is the proper thickness of plate to run on the 226II Sprint? Also what would the packing be for that plate? We are currently running a 12 mil plate but have been told that we should be running and 8 ml. We are having some issues with premature wearing on image on plate and are trying to isolate the problem. Thanks
    I think you mean thou not ml (unless ml means something else). But kmoimt is right, there should be a id plate at the op side of the press that shows the info.
