Man Roland 305 Console Error
printingtx
2016
6
USA
Can someone help me with this, we are installing a Man Roland press and get the following error.
Hello printingtx,
for the error UWR station 3 and 6 invalid data input, your press is 5 colors so the station 3 is the SPS general at main cabinet +AX rack A354 ans the station 6 is the printing unit 3 rack A350, first you must check if the cables betwen units are correctly pluged pay attention to nomenclature writing at each cable.
the other thing you must verify the jumpers for the station 6 , in board A342 at PU3 must be pluged a jumper in position 6.
another posibility is the safety input board is defective at PU3 rack A350 board slot 2, please send picture for this rack to check the inputs...
for the sps general check if all boards are correctly pluged sometimes the vibration during transport loose the boards out of position just macke sure are tightly pluged of course correct them with machine off.
Best Regards
  • you can interchange board rack A350 slot 2 betwen PU3 and for example PU4 if the board is defective the error must change to station 7
    input board defective at slot 3, 4 or 5 can send the same error , now you know how to isolate the fail and order spare parts.
    Best regards
    Best regards
    Now this is what I am getting:
    First error solved, Thanks. Now This is what Im getting.
    Please help solve this error and thank you
    What does "same problem" mean? There are 5-6 different problems in this topic.
    PP If you want the diagnoses to be accurate, read the diagnosis messages in German. The translation is often misleading.
  • Is the engine with a tachogenerator or incremental? If you don't know, take a picture of the motor.
    Take a picture of the power supply of the main motor.
    Most often the problem is in the wrong n = 0
