Man Roland 305+L+V+T
Ruslan
2019
6
Вінниця
Hello, we have a Man Roland 300 printing machine in the complete set Typ: R305 + L + V + T, 1997.
We have a section for varnish on the machine. There is a frequency converter Siemens Micro Master 6SE3114-0DC40 . After installing a new converter on the varnish section and after starting the varnishing program, an error message started to appear on the error board. Roller drive problem (error code 3600700). We see all the parameters on the frequency converter, but we do not know what they should be for our complete set. Please provide information on the parameters that must be entered for the correct operation of the equipment.
hello,
is this inverter from manroland?
if not then you need to load the parameter set file to the inverter which came with your machine with help of parafin program and some adapters, converter RS232 to Rs485 and serial cables.
  • hello,
    Sorry, we do not have a floppy with the settings. but we can enter the parameters manually on the inverter itself. But we need to know the values of all parameters.
    then try to collect values from old part by replacing EPROM with new inverter if possible
    We thought about this option, but checking the old EPROM for the presence of information in it was unsuccessful. now this cannot be done.
    when you get the inverter from manroland normally the disk with parameters are enclosed. if you have buy the inverter in internet you can try to replace the eprom from the original inverter butif this is defective then is not possible, in the other hand the machine has a cardboard box with the set of software and parameters diskettes you should have this enclosed to machine when buy it
