Komori Sprint Electrical Problem?
ChrisH
2010
19
US
We have a Sprint that is having a issue and we don't know what the problem is. When the press is running the feeder shuts off, clears the sheets and the buzzer comes on. The only way to clear this is to shut the power off and turn back on. Also the overload on the oil pump contactor trips often. Is this related?
anything to do with beepin tends to be oil or lube related. do you have enough oil? if the oil pump is tripping maybe your oil filters are full of ****??
  • We have oil. Will check filter. Are there other filters besides the one at the pump that has the handle that you turn?
    Better check the pump motor also. If the thermal is tripping soon after resetting or it won't reset for a time, there's something binding, easy to check, take the cooling fan cover off and spin the motor via the fan blades.
    Also check if the preset sheet counter is turned on. It sounds like oil pressure though.
