kuehnptg
- 2013
- 4
- usa
When we press the start button on our MOFP the bell goes off. Then we press and hold it again, there is a slight delay and the machine starts up. Recently, after the bell, when we push and hold the start button the machine will not start. This usually is after the machine has been running. It never happens when the machine is cold. I am wondering if heat in the electrical cabinet could be an issue. We opened the panel and put a fan 2 feet away to see if that helps. Not enough info yet. I also thought, since there is a delay after you hold the on button, if there is a timer switch that may be malfunctioning. Thanks for any insight.
