Colour Management -- best practises for tints and screens?
19
US, Owings Mills, T. Rowe Price Associates
Hello:
We are running iGen 3s and have a heckuva time getting the colours right when the original file is built with tints/screens of a Pantone. Although we recommend to our internal designers that they work with 100% Pantone values (i.e., find a 100% pantone value for the screen you like and use that Pantone), such recommendations have failed to yeild wide adapdation.
So, I'm asking the iGen operators and experts out there: What's your best practise recommendation for matching tints/screens of Pantones? We are running in a GRACoL-7 space.
Any input is welcome, and I thank you in advance for your insights.
Cheers,
DB
Using Pantone spot colors in printed jobs can give mixed results. Ultimately, I convert everything to CMYK and use TRC's to control color is the areas that need corrected. Spot colors do not adjust when using TRC's, so converting to CMYK does the trick.
  • Thanks for your feedback, 2ampress! I should have noted: we run all PDFs through a hot folder that converts Spot-->CMYK. But doing this still gives us mixed results with tints and screens.
    We've been fighting that battle too. Here's what we've resolved to do:
    1. Bounce the file back to the designer/client and remind them of our requirements for PANTONE screens.
    -or-
    2. Convert the tints to CMYK
    -or-
    3. Turn Spot Color Matching OFF & run the whole job in CMYK
    -or-
    4. Put on a blindfold, click print, and play dumb.*
    * Success rate is minimal with this tactic. There is a 9 out of 10 chance you will experience light-headedness, bleeding of the ears, and extended time off from work in the form of termination. If symptoms continue, stick with options 1-3, or call your mommy.
  • We follow ddigen3 #1-3 practice. I quit doing #4 sometime ago.
    When it comes to color correcting that would be the deference in having an operator or a pressman.
    Over and out
    Jim :cool:
