generalbatzorig
- Joined
- 2012
- Posts
- 43
- Geo
- Colorado
I am printing an art book with spot colors. Yesterday we started the printing, but there was a problem with the spot colors.
The Blue areas in the artwork use Spot color + Cyan(60-80%) + Black(3-10%). The application of the spot color is not flat or 100% solid, but it is continuous tone 60-90% coverage as the artwork has visible brush effects. In the areas (Blue) where it is covered with 3-10% black, a checker pattern effect is appearing on the print. This pattern is not there when I see the plates. But somehow this pattern shows up on the press somewhere from the plate to paper process. I don't know what is causing this pattern.
The images I attached here are just the examples of the artwork and do not show the pattern that I am describing. The printing machine uses LED fast curable inks. Can any one tell me what is causing this pattern effect? This pattern is quite obtrusive and easily detectable with naked eyes. We need to solve this problem very quickly.
