alex5213
- Joined
- 2012
- Posts
- 9
- Geo
- mexico
I use this printer for print business cards on 11x17" paper loaded on "special tray (5)", i have problems when i try to print business cards for both sides, the print not match, i print the front of business cards first and then load again the paper on the same tray and print the back of business cards but the print not match for about 2mm, i already verify that both images are centered to the page, disable the "margins" on printer driver and still have the same problem, the image looks like 2mm moved ( images not match ). Also i already make another test drawing an small cross at the center of the page, print in both sides and still the same error ( the print not match ). I use corel draw to print directly to the printer, also i already try to export the page to PDF and print from acrobat and still the same problem. I don´t know how more else to look
