Qm 46-2
Chouse28
2015
Regina
Hello,
I was running a job and went to go change the plate, and the press stopped not in the correct position for a plate to be loaded and now the "load plate indicator light" is blinking and the press wont do anything. I can't put it in neutral or anything. The only thing that works is when I push the "feed paper" button the motor runs, but obviously since the press can't run it doesn't do anything. Is there a way to clear the plate load indicator error?
Thanks in advance.
Chris
Open top plate guard, open front door, turn handle till plate eject light flashes & then push plate eject button.
Machine should be reset now.
  • Alright. I will try that tomorrow. Thank You.
    Also during the same run, I had idled the press and when to go start it back up it wouldn't go again. I had to turn off the main power and then it worked. Any idea what would cause that?
    Chris
