Komori Lithrone Varicam
You never mentioned the plate hangers, what is the exact positioning problem?
Where can i find the timing sheet for this machine?
Where can i find the timing sheet for this machine, i bought a new varicam and need to program it, by the way it seems this machine has different pieces from different years (1989-1992) where can i find the serial number of this machine?
  • The serial number is located on the delivery side of the of the fourth unit operator side on a plate that will say "L426...". It should also be on the "Electrical Sequence Diagram" book. The timing sheet belongs in a tray on the feeder electrical cabinet door
    I think it is 743 :) Under the L426 it says 743 hehehe sorry i feel so dumb now
    What i have for sure now is that inside the electrical cabinet there is no timing sheet :) where can i find it online?
    It seems we programmed the varicam but the machine dosent make anything how do i know if everything is ok with the varicam?
    What is the history here there is a long gap between your posts. Did you get this working in September? and are you now having new problems.
    There are times when you specialized help this sounds like one of those times
    We got the "OK" signal from the Varicam to the PLC. There was another alarm sounding and the press wouldn't run. I had Ezequiel check the oil filters and havn't heard back from him so I hope it is running now.
    do you have the original factory table for the press ?
    what press is it ?
  • vari cam problem
    sir.
    i have original factory table with me machine is lithrone 226p varicam type is
    vs-5e problem is it is not showing any degree in the display
    That could mean that display unit needs to be replaced. Is the press still operable?
