thldesign
- 2016
- 2
- United Kingdom
Hi Guys!
Im new to the digital production printing I bought a Xerox docucolor 242 and I have since had it serviced etc spent a fair bit on it so far as it was not working in 'perfect' condition.
I have since had an engineer out on a number of occasions and its now up and running however I am very new to it and today I found this issue:
I have to manual duplex the prints as the paper kept getting stuck as the engineer said a part needed replacing which was the one near the right hand side door the unit inside there but its costing me too much as yet to replace! He has since turned the duplexing off but dont know how he has done this etc (from the settings im guessing) as I was thinking today to turn it back on and see if there is still the issue with thin 170gsm paper supposed to 250gsm it was running?
However today I tried to print off some leaflets so what I did was on a B4 paper I put 4 x A6 Size on and when they printed I managed to manually shift the design so the cut marks more or less add up which took ages and a few sheets wasted. However once it added up I noticed nearly ever couple pages printed where the same and get the odd one or two being different.. Should this be the cake or should they all print of exact?
I am also noticing the paper is slightly slanted nothing major on some but some more obvious than others..
It causes a big problem when im cutting them as I have to cut them at an angle to assure a straight finish so I have to manually match the crop marks and then cut them..
Could the paper be an issue as when im selecting the pdf its coming as on the options as JIS B4 which is different size for b4? or have I ordered the wrong paper as I noticed the fitting is fairly loose too. The B4 paper size I ordered was 250 x 353.
Thanks guys!
P.s. I am not very technical at all with the printer as I am starting up with very very basic stuff.
Thanks guys!
