Want to complete remove ink Station Heidelberg
ramadanrunjeva
2015
Ferizaj, Kosovo
Hello.
I want to buy used Heidelberg 102 5 colors press. I found a good press but with more colors then I need, and with some problems in one unit. My question is: is it possible to remove an complete unit form ex. 6 color press to use it as 5 colors?
Machine is with CPC, Cptronic.
yes , it is possible but you will need a HD expert to do the job and set it up as a 5 color.
If he dose not know what he is doing best , you will be deep in SHXX...... so make sure before....
  • What 's the reason for removing?
    Use the last unit for varnish, wet in wet...no problem.
    Maybe you can use it for die-cutting too..
    Or use the 1st unit for dusting and cut down on blanket washes.
    Possible but better leave it as it is.
