UV dryer
Oleh
2015
8
Ukraine
I have a problem with the IST Strahlentechnik D-101-3cmk-IR/1iHd uv&ir dryer. The lamps turn off during operation. After turning it on again, they work again.
Thank you.
Test the electronic control board for lamp, for dry+ colder solder joint... and reheating the board.
Look for loose wires, corroded, broken, connector oxide, or defective..!!!
or Defective lamps for Older...!
  • Hi sir .
    The issue you're describing with the IST Strahlentechnik dryer could be due to various factors. Check for possible overheating, loose connections, or issues with the lamp ballasts. Additionally
