I would try substituting the cobalt dryer, which is basically a top dryer, with something that dries either from the bottom up, or a combination dryer which dries from the middle out, in both directions. Cobalt drier works great on a coated sheet, but not so well on uncoated papers. Even with the best dryers, you will have as mentioned earlier, a harder time drying on many uncoated sheets. The best way around this, whenever possible, would be to try scheduling your work so that you can allow overnight drying of these sort of jobs. Its also very important that you run the ink film thickness down as low as possible. Inks with strong pigment will be your friend when printing on these types of paper because you will be able to achieve color running less ink.
