Technotrans beta.d 40 L communication error
ElectroNick
2022
18
KR Bishkek
Hello brothers!
We have error F013 - comm. addr. 3 - TBC/TBU. I think it was problem with battery. Nothing works now. Help us, please.
This error has following meaning:
Communication error of the CAN address3. Loss of connection to Basic electronics of the dampening solution device (Exits of Basic electronics not set).
Check in the TT el. cabinet if there are some LED diods on the TBC 50/51 or TBD 50 Board. You can also check power supply on this Board on the ST20 plug.
  • Yes, there are two red LED diodes "RT" on the TBD40.1 plate. But one of them blinks and another lights. If I remove Can connector "ST3.1" nothing is changed.
    Nice to here.
    Can pls share the pix of particular area where you have change the components
    I hope this helps you. Although there may be different reasons. )
    Thanks, friend! I've got exactly the same issue on Beta.C (error F013). Circuit board is the same, firmware TBD 42.1
    Спасибо, дружище. Сегодня словил точно такую же фигню, технотранс бета-с. Плата такая же, прошивка 42.1. Хоть знаю куда копать.
    Thank you very much! The problem with DC-DC converter confirmed! I replaced it, and problem was solved.
    I also have same problem.
    F013 - comm. addr. 3 - TBC/TBU. This error showed first time for about 2 weeks ago. This usually happens on morning when machine starts. After few power cycle on & off it starts working. After it starts works it keeps on working (except for some time) whole day. May be those two capacitors has to be changed. I hope its not DC/DC converter. Any Suggestions?
    img_20220526_235725-jpg.11504
  • No
    This error is belong to the tb10 and dispaly controller
    And if you wish
    Then you to modify wiring changes
    Then it will run as stand alone unit
