Stahl kd 78 error code 63
HamedNDIAYE
2021
9
Kinshasa
Hello friends, I am new to this forum, the problem I have on my folder: error code "63" is displayed when powering on. Can you help me? Thanks
Hi sir;
Cause; Sheet monitor ower delivery.
Do this; Remove pile jam
Make sure the pieces up preselect are available
Clean the light sensor on the carrier table
  • Ok thank you very much, I will see and verify the causes mentioned and get back to you ... thank you again
    Bonsoir monsieur, j'ai fais ce dont vous m'avez conseillé et quand j'ai redémarré la plieuse j'ai eu ce nouveau message sur l'écran, merci d'avance
    Good evening sir, I did what you advised me and when I restarted the folder I had this new message on the screen, thank you in advance
    Reset the Cpu , measure the Power Supply Vcc from CPU.
    Blessing
    Here is how to do it, look the schematic Pins via Google,duckduckgo.com, Yahoo...etc
    Attached
    Blessing
    hello, with this diagram I understand better and easy to achieve .. I will come back to you after a test .. thank you
    Hello sir, as advised, I found the circuit of the CPU, but I do not see <which> (?) to reset
    I looked at this data sheet, but nothing tells me which pin to reset. I'm not a great electronics engineer ... please help, thank you
  • Помогите пожалуйста решить проблему. Остановился и признаков жизни нет. Датчики проверены, работают исправно. Stahl kd 78 . Заранее извиняюсь, если обратился не по адресу. И спасибо за любую информацию. Если есть инструкция в электронном виде, поделитесь пожалуйста.
