Baron Wang
- 2026
- 14
- Shanghai, China
A spot UV mask can be technically correct while still being easy for a customer to misunderstand. A black shape on a separate page may look like extra printing, while a composite preview can hide which parts are meant to stay matte.
I'd pair the artwork with a clearly labelled coating overlay from the same revision, then check the actual separation in the exported production PDF. The preview explains the intended coverage; it doesn't show the gloss or feel of the finished surface.
How do you present that approval in your workflow? Do you keep the mask and composite together, and how do you flag a late artwork change that also needs the coating mask updated?
