sm74 di issues need help
Discussion in '4-Color Offset Presses +' started by CajunCowboy, Jun 12, 2020.
  1. CajunCowboy
    CajunCowboy New Member
    Jun 2020
    Dallas
    We are currently running a sm74 di, The press will not boot without the imaging computer. We are using a platesetter so we really do not need the unit. There is a variant code to turn on and off the di portion. When we do it comes up with a dynamic fault red cannot run press. There is no location and nothing in service menu. We really want to disable this. If there is anybody that could help with this issue I am willing to pay a bounty. Thanks in advance.
  2. CHOCK
    1,738
    Hope you are well.
    If a malfunction occurs in the initilization phase, the detected Init-Error is displayed on the main control
    panel.
    Press operation is no longer possible.
    Can you send me a Pic what show in the imaging computer??
    In short, you must test first: 1) the power supply in the input of main transforme(primary winding)
    2) secondary winding of the main transformer, must be in 10% of tolerance up of down.
    3) if are o.k test the input and output of the GSM (bridege rectifier for to differents modules of machine) likr +48Vdc for G11+G12, use the schematic diagram.
    Let me know, if you have cptronic compact??
    Blessing
  3. mrheidelberg
    mrheidelberg Senior Member
    Jan 2008
    673
    United Kingdom
    74
    74 DI will NOT be Cptronic compact
  4. PWInc
    PWInc Member
    Sep 2020
    16
    Canada
    Was this fixed? What does it show in the screen? What is the software version of CP2000 and IPC version of computer, MC-xx-xx..? Can you share a picture of the problem?
  5. CajunCowboy
    Jun 2020
    Dallas
    The press will boot just will not let you do anything, No error di error. When we fixed di raid it all works fine.
  6. PWInc
    PWInc Member
    Sep 2020
    16
    Canada
    I thought you were getting a dynamic test error when you turn off the DI variant code. Again, what is the dyn test error you're getting when the DI variant code is turned off ? What else was done or have been tried to disable the imaging section?
  7. CajunCowboy
    Jun 2020
    Dallas
    All I want to do is turn off imaging and run free sanding. We use a platesetter now.
  8. PWInc
    PWInc Member
    Sep 2020
    16
    Canada
    It can be done and was already done before.
  9. CajunCowboy
    Jun 2020
    Dallas
    Who could I contact?
  10. PWInc
    PWInc Member
    Sep 2020
    16
    Canada
    I can but I'm in Canada so travel is out. There must be somebody in States that has fine this before. Most ex-Heidelberg electrician must have known this.
  11. PWInc
    PWInc Member
    Sep 2020
    16
    Canada
    There must be somebody in States that has done this before. Have you asked Heidelberg?
  12. Mathew
    Mathew Senior Member
    Apr 2010
    360
    Kolding-Denmark
    Are you still struggling with this issue?
