Sm 74 kvt 7ffb
Discussion in 'Heidelberg Printing Presses' started by Nagarajan, Nov 30, 2020.
  1. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    I have a kvt 7ffb & blt _ con 3fff error on during break test please advise me
  2. junker1984
    junker1984 Senior Member
    Jan 2010
    799
    US, Midwest
    Given your errors are showing up on "INIT Test", code translation will direct you to checking incoming voltage. Specifically, it reads,"Power part test cannot be carried out,conditions for testing not fulfilled (In most cases wrong supply voltage). Press does not start running." Suggest you verify 3 phase power, and check secondary voltage transformer.
  3. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Input voltage is normal,break voltage also normal
  4. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
  5. Beguin
    Beguin Senior Member
    Jan 2020
    145
    Côté d'ivoire
    hi please, it's kvt blinking or blt-con blinking.
  6. Beguin
    Jan 2020
    145
    Côté d'ivoire
    it doesn't mean anything according to the research I did.
  7. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Kvt & blt-con both r blinking, press doesn't move What is the problem
  8. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Cp tronic error code
  9. Beguin
    Jan 2020
    145
    Côté d'ivoire
    Blt-con 3fff
  10. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Blt-con 3fff,remedy sir
  11. Beguin
    Jan 2020
    145
    Côté d'ivoire
    hi sir watch check the MSK, there may be corrosion or a component to perform. For the KVT I think it is normal since it does not give any information.
  12. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Ok sir I will check
  13. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    Kvt 7DFB& mot 7FEf
  14. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    What its mean sir
  15. Beguin
    Jan 2020
    145
    Côté d'ivoire
    Please, I would like to know if it is still in Dyn DYN test or INIT test thank you. Here is after research in DYN test
    Nagarajan likes this.
  16. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    This dyn test sir
  17. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    This three phase motor sir
  18. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    give me brief error code sir
  19. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
    What is the remedy to resolved it sir
  20. Nagarajan
    Nagarajan Member
    Nov 2020
    15
    India
