pressmachines
- 2008
- 68
- Philippines
Hi,
SM 74 - No fault in INIT TEST 1 to 13. But DYN TEST 12 SSK1 7F7F fault DYN TEST 13 SSK2 7F7F fault. Check and install already new NTK 5 volt and NTK 24 volts.
Always fault goes away after switching off and switching on the main switch of the machine one to two times. Sometimes there is fault sometimes there is no fault, but most of the time there is fault.
If the fault occurs the SSK 1 and SSK 2 boards - there is no flashing of lights and the values of the service display SSK1 and SSK2 are "0" Please see screen shots below
Tech says the SAK2 board might be the problem, have a used SAK2 board which I test, the outcome was same as above. Cannot rule out the possibility the the SAKs boards that I have are defective without any new SAK2 board to test, but can the 2 SAK2 boards with I have here have the same outcome.
Any help or suggestion is appreciated. Hear from anyone soonest.
