Slight double on 50# stock
Discussion in 'Heidelberg Printing Presses' started by Jack liston, May 14, 2022.
  1. Jack liston
    Jack liston Senior Member
    Sep 2019
    275
    Connecticut
    Hello gentlemen I am experiencing a slight double on the outside edge on 50# stock cd 74 it is happening on transfer cylinder and only on ds not affecting heavier stocks any input appreciated double is only sideways .
  2. turbotom1052
    turbotom1052 Senior Member
    Oct 2008
    1,054
    Vermont
    Im assuming that because its a 74 that your running short grain stock??? If your cutting your stock down in house from a larger long grain sheet, you may want to consider buying your paper long grain finished size if available. If not available you can purchase your paper in 38"x50" size, and quarter it to be able to run it correct grain. Considering that the CD was really designed for heavier substrates, it does not surprise me that a 50lb sheet is doubling a bit. Any doubling situation would usually point first at gripper settings. This of course assumes that youve ruled out problems with your stock, and its grain.
    asem alsafady likes this.
  3. Jack liston
    Sep 2019
    275
    Connecticut
    HELLO Tom thanks for your comment. With supply chain issues I guess they are using whatever is available/ paper is not what it used to be.
