Running one color on a Ryobi 3302?
Discussion in '1-Color and 2-Color Offset Presses' started by tofer, May 14, 2007.
  1. tofer
    tofer Member
    May 2007
    9
    Can one run one-color jobs on a Ryobi 3302 as easily as on a one color press?
  2. thector
    thector New Member
    Nov 2007
    central illinois
    absolutely.
    you certainly can you will want to run some sort of roller lube in the unused head to reduce friction and heat on the uninked rollers. I use hurst off duty
  3. GiantEagleBrain
    GiantEagleBrain Member
    Dec 2007
    6
    United States, Bedford Heights, Ohio
    I normally pull idler and ocillator rollers from the non printing unit. If you do so, make sure to leave it in nightlatch, and you know that you have the right rollers out if you inch the press and the forms dont move. The press manual should list the rollers to remove.
  4. MidwestPrinting
    MidwestPrinting New Member
    May 2008
    Missouri
    Squirt oil on the rollers of the unit you are not using. They MUST have lube on them.
  5. discountprintingservice
    discountprintingservice Senior Member
    Mar 2007
    141
    Georgia
    Oil is not a good idea, I would use roller lube which is made for roller lubrication, straight oil can cause a number of problems including breakdown of the rubber rollers, some hydraulic oils are also caustic...
  6. Swifty2
    Swifty2 Senior Member
    Mar 2013
    300
    Ma.
    crisco if you are a cheapskate LOL
  7. OkiTech
    OkiTech Senior Member
    Jan 2008
    832
    NEW JERSEY
    Yeah, roller lube is a designated product so it should be the best choice, only thing - it has to be washed up before inking that tower so if you don't feel like it, pull few rollers out as stated in previous posts.
  8. Offset George
    Offset George Member
    Jan 2015
    18
    United States
    We would run a small amount of transparent white on the non printing head to lubricate rollers and to help pull out old ink so our next color job was the proper pms color.
