Rubio 3302 Impression problem
shekar_msc
I am working on second hand Ryobi 3302 two color baby offset printing machine.
This machine suddenly developed a Problem with its Impression system. What happens is, the Impression System works perfectly when speed is at very low speed (I.e when 1000 iph button is pressed on operator panel). Again when speed is increased to 3000 to 4000 iph Impression goes On and Off intermittently and at Higher speeds the Impression doesn't come On. Counter isn't working.
Strange thing is when Feed sensor is disconnected only impression works on low speed only. Similarly when Paper in_Feed Sensor (Near Blanket Cylinder) is disconnected COUNTER works fine
Tried cleaning sensors. No use. Checked Sensor Controller on another same model machine it works fine in that machine.
Unable to solve the problem or localize it. Please advise. Thanks in advance.
  • There's a similar thread like this one. You should see it at the bottom of the screen. It's called "No impression trip on 3302". That might give you some more info. He had some loose wires on one of his sensors. It sounds familiar to your problem.
