Relocating Polar 90
Discussion in 'Cutters and Trimmers' started by Thayanithi Kokulan, Oct 27, 2019.
Tags:
  1. Thayanithi Kokulan
    Thayanithi Kokulan Member
    38
    Sri Lanka
    At the moment i am having polar 90 at my premise and i am planning to move that to my back side store as the store entrance is small i am unable to move it fully.
    Can any one advice me whether it is possible to move the polar cutter by removing the table, motors, glass and other components of the polar cutter.
    Please refer to the attached images of the polar cutter.
  2. synthology
    synthology Member
    Apr 2017
    22
    us
    yes if you know how to put back
  3. CHOCK
    3,058
    You can moving the polar complete, without touching nothing Only using Forklift and Wood Pallets
    between the Clamp .,use Carefully and slowly.
    Attached is there scheme.how to do it.
  4. Tomas
    Tomas Member
    Dec 2017
    6
    Slovenia
    I have the same problem, moving polar :) Can i grab it under the table in front with pallets on fork lift and jack back of the table on a troley ? And is it enough to be only 10cm from the back
    wall for servising ? Its polar 92 y1999. I will move it only 8 meters on leveled floor.
  5. CHOCK
    3,058
    You can do the same , attached is there the way , how to do it with carefully
    Good luck
    Blessing:)
  6. Isaac B HOU
    Isaac B HOU New Member
    Apr 2024
    Houston, TX
    I'm moving a Polar 78 out of a building that can't fit a forklift. Does anyone have experience moving one with a gantry crane?
  7. CHOCK
    3,058
    Hi Sir:
    Will send you details, tomorrow,now is late.
    Blessings
  8. CHOCK
    3,058
    Attached is there as you can do it, with a gantry crane.
    Good luck.
  9. Adil
    Adil Senior Member
    Nov 2021
    1,353
    Casablanca
  10. rspblake
    rspblake Member
    Dec 2013
    38
    london
    Polar 78 has it own lifting point on the top of the machine under the screw on top cover
    It just rolls up and you can use a gantry with a block and tackle to lift.
    It will lay backwards a little when lifted so you need to lift up at the back till you get a little height.
    When you drop it down lift the back up at the end of the rear table and the weight will counterbalance and level machine if you don’t lift it will fall backwards
    And you don’t want that happening
    Rear legs should be tightened and locked up after.
