Printing on Silver laminated uncoated boards
alliswell
2012
6
india
Hello friends ,The sample given by the client shows single color meganta on silver laminated uncoated boards. how do you print on silver laminated uncoated boards?.The ink is not opaque.It looks like uv.But it was printed by one who does not have the facility.How do you do that in single color machine?.Pls some one help
print First white , and in the 2nd run your Magenta
UV is one way , but not the only way
you CAN print Silver laminate with conventional ink if you do it right and best with a coater & water base coating
  • before you put good materials dowm the drain... talk to me , i will guide you (free od charge)
  • Dear Sir,
    I have Xl75-5-L it's possible to print on sliver laminated board with conventional ink??
    e.g like the box of signal toothpaste ( to give the colors CMYK metallic effect )!!
    Yes it is possible
    It is possible to print on metalic laminates with regular ink , but it must be done RIGHT
    Not like on regular paper , the laminat will not take in any ink - it all stay's on top.
    so you need to make sure:
    A. your ink will dry right
    B. your ink will be adheasive and stick to the surface
    It is possible to print also plastic this way , but you must be carefull and capable.
    UV dryers & UV inks are also a possibillity - to enable the same resulr at higher speed and quicker dry time.
    If you need help with this - let me know...i am very close ...only abour 2 hours away :-)
    Meny
