Polar N115 touch screen problem
pal006a
2021
Uk
Hi friends . Good day . I have problem with my Polar N115 cutter . working fine but shows ( Touch screen is active ! ) the touch screen function not working . I replaced new touch panel but still same problem any help ?
Please do the calibration as follow:
Important: In order for the calibration to be correctly done, a touchpad stylus, or something similar is
required. Because the 18.5" displays are significantly more sensitive than the 15" displays from the X / XT
generation, problems can arise if a finger is used for the calibration.
Begin the calibration mode by pressing an area on the Touch in the free field above the keypad until the
progress bar, which appears beside the Touch-Key „MANUAL“, indicates that it is complete.
The beginning of the initial one-third of the progress bar’s movement is indicated by a single beep from
the machine. After completing two thirds the machine will beep a second time and when the progress bar
indicates that it is complete, and the machine changes to calibration mode, the machine will beep a third
time.
The display shows the calibration mode with a white-colored cross in the upper left corner. A total of 25
calibration points are now displayed for touch calibration.
Touch the center of each white-colored cross. A single beep will sound if the actuation was correct. The
calibration point jumps to the next field. A wrong operation will cause five beeps to sound. The calibration
point will not jump further. In this case, press the calibration point again. At the end of the calibration, i.e.
when the last cross is touched, the machine will beep three times and automatically jump back to the data
image.
If problems occur during the calibration, the machine can be turned off
Blessing
  • Hello! I have same problem with touchscreen. Did you solve this problem? I think trouble with board ADAD10 063421. I changed touch screen but, problem isn't fixed.
    Hi Sir:
    Please test the: regulated power supply + 24 VDC, beofore to exchantge the board .OK
    Merry Christmas, And Happy New year.
    Hello,
    Thank you, for the answer. But if trouble was with +24VDC Display not working. In my situation display work, backlights work, trouble with touchscreen function.
  • Good evening, my name is Adolfo Ruiz. What's the solution to get the touchscreen on my Polar N115 Plus working? The image is frozen, no icons are activating, it displays the measurement but the touchscreen is unusable. Thank you.
    1) Test the voltages for the touchscreen, according with his wiring diagrams electrical.
    2) Look for loose cables, corroded, or broken pins.
    3) Open cables, test it with DMM tester.
