Binderyguy
- 2017
- 2
- united states
Hello, Okay so the problem I'am having is I go to cut and whether I step on the pedal or use the two cut buttons the clamp will come down but the blade never moves. You can here the hydraulic sound change as if its about to cut but it just doesn't, and then you get the error "maximum cut time elapsed (469)" after a few seconds. I have tried simply restarting the machine, I have checked all circuit boards for burns or evidence of relays burning out and found none. All fuses and breakers are good, belts are good. I'am not sure where to go from here. Anything helps, thanks in advance!
