Please can somebody tell me what error 111 on Ryobi 512 means
leon909
2010
13
Shepperton UK
Hi Everyone.
I washed up on my Ryobi - Went to start and suddenly an error code 111 on the display. Please can somebody point me in the right direction as to the fault and how to fix it.
Any help would be very much appreciated.
Update to this - hope it helps somebody else. It was a faulty micro switch on the rear chain guard which then stops power to the inverter. There are 2 contacts on the micro switch so it still appeared to be operating ok on display when opened.
ERROR 111 Solved :)
  • Hi Leon909,
    It is a great to see that you have updated your situation and how to fix it for the future readers who might need some help same as you. I have exactly same problem. my user manual is in French so i can't understand it. So please describe it a little bit how to find the faulty micro switch and where it is exactly located and please attach a screenshot if it is possible. Thanks for your posts and at least it gave me where i should focus on.
    Regards,
    Manlai,
    111
    Hi
    I will send you some pictures tomorrow when I am at the machine. On mine it was the micro switch on the delivery above the chain delivery that was causing the error. Did you move this guard prior to the error showing?
    Cheers
    Brendan
    hello i have the sma issue error 111 please help me leon 909, can you send me a pictures of the microswitch and where is it in the ryobi?
    thankyou so much regards
    where on the machine picture or information thank you 512 Ryobi error 111
