Moving Polar 78 without a forklift
Discussion in 'Cutters and Trimmers' started by Isaac B HOU, Apr 30, 2024.
  1. Isaac B HOU
    Isaac B HOU New Member
    Apr 2024
    Houston, TX
    Moving a Polar 78 on the second. It's in a building that can't fit a forklift. Does anyone here have any experience moving a mid sized Polar with a gantry crane? Any advice would be greatly appreciated.
  2. CHOCK
    3,056
    Attached is there, the schematic, how to do it, for using gantry crane.
    Good luck
  3. Isaac B HOU
    Apr 2024
    Houston, TX
  4. CHOCK
    3,056
    You're welcome
    Blessings.
  5. Adil
    Adil Senior Member
    Nov 2021
    1,352
    Casablanca
    Hi sir this is a live exemple .
  6. rspblake
    rspblake Member
    Dec 2013
    37
    london
    Polar 78 has it own lifting point on the top of the machine under the screw on top cover
    It just rolls up and you can use a gantry with a block and tackle to lift internally if needs.
    It will lay backwards a little when lifted so you need to lift up at the back till you get a little height.
    When you drop it down lift the back up at the end of the rear table and the weight will counterbalance and level machine if you don’t lift it will fall backwards
    And you don’t want that happening
    Rear legs should be tightened and locked up after.
