MO Board 91.198.1333
Discussion in 'Heidelberg Printing Presses' started by swilson513, Mar 12, 2021.
  1. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    We have an old (1987) 4/c MO that keeps blowing the bottle fuse in the water unit. We swapped out this board with another unit and the problem followed the board. Looking for a used one or someone to fix the one we have. Or any other suggestions.
    thanks
  2. Jack liston
    Jack liston Senior Member
    Sep 2019
    275
    Connecticut
    Contact demers In port Charlotte fla 941 625 7278
  3. CHOCK
    2,877
    Hi sir
    Would you please send me a Pic from bottle Fuse in the water unit?
    I do not believe that his problem is the board, in another external elements, then that you swap the board, and the problem remain .
    That is indicative , that problem is external, NOT the electronic board, please send me a Pic.
    Thank you in advance, sincerely
  4. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    Chock thank you for the reply. The board that I swapped it with was from the same press different unit. The problem is following the board. For example I took board out of unit 2 that was blowing the fuse and put it in unit 1. Unit 1 is now blowing the fuse and unit 2 is not.
  5. CHOCK
    2,877
    You did understand my question
    In others words, What Control That electronic Board?
    Send me Pic(s).
    Blessing
  6. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    Picture of fuses and boards. 2 fuses per board.
  7. CHOCK
    2,877
    If the control electronic board, drive some Motor or solenoid , this must in Short Circuit..Or some mechanical problem
    You must take to machine shop repair motor or solenoid, winding is in Short. By that reason are blowing the fuse.
  8. junker1984
    junker1984 Senior Member
    Jan 2010
    1,036
    US, Midwest
    Not so sure about that, as swilson states that after moving power supply, problem follows power supply .
  9. Mathew
    Mathew Senior Member
    Apr 2010
    534
    Kolding-Denmark
    Hello Swilson,
    Behind this PCB, there is a row of 6 x SCR (Thyristor). Try to replace all of them. I had seen before one of them damaged and blow out fuse instantly.
    Good luck
  10. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    Thanks, we have them on order. Hopefully that takes care of it, used board is about 2k.
  11. Mathew
    Apr 2010
    534
    Kolding-Denmark
    I can repair the damaged one if you like.
  12. swilson513
    swilson513 Member
    Oct 2009
    80
    USA
    If the thyristers don’t work I will be in touch.
    I also have a spm board that’s in a 2003 SM74 that’s mounted to some type of slide rail, any idea how to get it out? It looks like it should come out like the relays do but I couldn’t get it out.
  13. Mathew
    Apr 2010
    534
    Kolding-Denmark
    Push the metal plate downward and pull it out from button.
