Man Roland 300 - Problem with CPL motor clamping
Discussion in 'Man Roland Printing Presses' started by QBAelectric, Apr 17, 2020.
  1. drukman
    drukman Senior Member
    Mar 2016
    279
    Bulgaria
    Not all versions are bооtibles . It is theoretically possible, but I prefer to use the system config.
  2. mendietta
    mendietta Senior Member
    Oct 2019
    112
    Slovenia
    Let him go first with floppy, if he mess something in dos then he will be in bigger problems...
    I always do like that, but I also have bootabile disc with LSR host and cpl tools...
  3. drukman
    Mar 2016
    279
    Bulgaria
    You're right. It is better for him to work than a floppy disk. Hopefully start. I prefer the hard drive because of the speed and DOS directory.
    mendietta likes this.
  4. Daniel.Sanchez
    Daniel.Sanchez Senior Member
    Apr 2020
    108
    peru
    Hi Mr
    you can try self-calibration.
    Have you changed the mercotac?
    The problem seems to be simple, I can help you since in my country we cannot leave the house, my email is Accesorios_graficos@hotmail.com
  5. QBAelectric
    QBAelectric Member
    Mar 2020
    33
    Poland
    I am very sorry that I am only answering now.
    According to your advice, I solved the problem after proper adjustment and carrying out the opening and closing procedure.
    Thank you,
    Now I have a similar problem with another station, but about this in a new topic.
  6. Daniel.Sanchez
    Apr 2020
    108
    peru
    On the display it tells you what problem you have; the cpl issue is not complicated
  7. AR MAC
    AR MAC Member
    May 2019
    7
    UAE
    hi drukman,
    I did read all conversations in this topic... i had experience with same problem CPL... but I didn't finished it...
    but I need to lookout the 19_m3d16.pdf file...
    please can you send me this file at samsungkzoom321@gmail.com ...
    thank you
  8. ayman marshaha
    ayman marshaha New Member
    Sep 2018
    turkey
    Roland 304
    Pasa.ofset@gmail.com
  9. Daniel.Sanchez
    Apr 2020
    108
    peru
    you can send video in emergency mode, to check how the servo motor works, or you can check which version you have,
  10. Daniel.Sanchez
    Apr 2020
    108
    peru
    there is a way to calibrate the cpl, without the console program, you can calibrate in that printing unit, with the emergency program
  11. imranuzun
    imranuzun New Member
    Jun 2022
    Ankara
    What is Mercotac?
  12. Daniel.Sanchez
    Apr 2020
    108
    peru
  13. Daniel.Sanchez
    Apr 2020
    108
    peru
    Transmisor
  14. imranuzun
    Jun 2022
    Ankara
    First of all, hello.
    My machine is roland 300 1999 model
    I am having a problem like this. 1 and 3 cpl die in position 4 gives error code 74 at stage 4.
    Why could it be .
    Note: Even though I tried calibrating operations, it gives the same faults.
    I await your replies, best regards
  15. CHOCK
    2,877
    Hi sir;
    Reset the Cpu, however measure the battery if have the voltage impressed? otherwise replace it.
    2)
    Perform a visual inspection : look for loose and broken wires, improperly seated connectors, loose or broken wires
    Dust + dirt + tear +wear
    Edge connectors are a common souorce of problems. Power down the system and remove the PC boards. Examine the edge connector
    for contamination and clean with contacts cleaner contacts. Reseat any loose components such as scoketed ICs) . Reseat the
    boards and power up.
    3) Power supply checks:
    Check the power supply for missing voltages and voltages out of spec. A digital multimieter DMM can be necessary, as
    voltage specifications are quite tight: logic supplies for example: must be within + 5% percent of 5Vdc. All the
  16. Asim Shehzad
    Asim Shehzad Member
    Feb 2021
    78
    Lahore, Pakistan
    hi,
    74 is "wrong position clamping motor" so check the potentiometer and motor itself for any defect/damage.
  17. CHOCK
    2,877
    Please do , that i did mentioned before
    3 steps Sir!
  18. imranuzun
    Jun 2022
    Ankara
    I had the same problem and found the error in the potentiometer. We were able to correct the error by changing the 5k 10 turn potentiometer.
  19. CHOCK
    2,877
    Great Sir.
  20. Azeng Azhari
    Azeng Azhari New Member
    Oct 2022
    Jakarta
    You can install in your laptop from disket cpl service tools, remove x3 from blue box weko in drive side
    Conect x3 from blue box to your laptop, but must use converter rs 232 to rs 485, cause x3 in blue box is rs 485, now cpl system controled by your laptop; there is a menu to check every motor inside cpl
